well my winter mods have begun!
#167
ok... so a ride report... air ride in back so far is the best set up i have had (done progressive 12" 412, 11" progressive, V rod shocks, HD bagger air shocks 12, bagger HD 11 air shocks, stock shocks, and Burley slammers) the adjustable is unreal! can go from a low slammed look that is like floating on a cloud, to a lifted up firm ride for ripping turns.... Race tech emulators = really did well to smooth out the ride and made a dramatic improvement in handling response. I did progressive springs, dual top out, emulators, 130mm fluid, 5 turns, and 15w spectro.... storz steering damper = BAD ***, nothing else really needs to be said about this sucker, completely adjustable and helps plant the front end, thanks Justin Mcginnis for hooking it up.... Super brace = just rounds out the package up front. The bike feels like it can rip a super bike track up.... Brembo front brake = less than impressed. Took so much work to make this thing work on the bike, and of course customize the caliper itself and the difference is a touch better than stock, if not the same, if I could do it all over again i would leave the stock brake caliper, shave and coat that. I only have about 75 miles on the bike so far... but that is the ride report!
#170
