well my winter mods have begun!
as always joe nice work. tell me more about that middle finger derby cover that would look sick on my scoot is it usable on a wet primary or need a dry primary for it?
i am still doign my hard bags at teh moment modified soem OEM tourign brackets to fit the dyna struts not super snug to the bike but not huge amounts out fro mit either
Joe, I have hated Rifle fairings for years. The original FXRP had a similar fairing and i hated those. Now having said that I really like what you have done with your bike so far and I can hardly wait to see how it turns out.
By the way enjoy those babies while you can. My baby turned 15 last week. I can't pick him up anymore cause he's 6"2" and 200 lbs!
ok well got a bit more done... as i mentioned this is going to be slow going as i am working on this when i have some free time from the shop and the 2 little ones i have at home... finally was able to score a brembo caliper, sucks ***** it is chrome, will make it a night mare to shave and suck a bit more for powder, but i got it decent priced for under $150.. with new braided lines this should be a nice little upgrade to the front brakes without having to do a ton of mods and spend a bunch of money... new braided lines all around, all new seals, all new fluid, black braided coverings for the lines, and new pads all under $275... thats a win!
last night i was able to cut out the turn signal buckets in the fairing... ran into a bit of a hick up. the fairing is not fiberglass, it is ABS plastic! so that will change the game plan for filling in the holes a bit, exp cause i have done a ton of glass work and ZERO abs work hahaha so looks like it is time to learn!
also going to make a bit of a trim for the swing arm to tie in a bit more blue
well did not get much done this weekend but every little step forward is a bit more ground covered
new goodyear braided lines came in, could not have them braided, so like every other cable, line, and wire i wrapped this with expandable tubing to keep it clean
cut some quick brackets to add some lower support
and then took some time to plan out how i am going to pull off these fills on the ABS
tomorrow i am going to get the white paint all stripped off this sucker, and start laying some glass!
