Spoked rear pulley?.
Those look pretty cool. Can't say I've ever seen one on a bike.
I don't like how the pulley in the first post has holes drilled through the teeth to get to the end of the spoke nipples. The ones in the third post don't have that, at least it doesn't look like it in the picture. Not sure how they put the nipples in with no holes, but I don't think I'd like holes and edges on the teeth of the pulley.
Guess it depends on how much torque we are talking about. For me, stripped threads out of every other spoke on 2 wheels in 2 years. Basically the center hub rotated a few degrees out of sync with the rim. Works like this, you know how in your minds eye you see yourself going thru the gears and it looks really cool, You catch 2nd and the front wheel comes up, 3rd the rear slides a little sideways, 4th the tire barks then you pull up to the next light with the back of the bike waggin like the tail of a dog worried if you can get it to a safe place before the rim falls off the hub. After the 2nd time I replaced the spoke rim for a cast wheel. i can't afford to keep replacing spokes in a wheel let alone in a pulley.
