Mag wheels on street bob spacer ?
Ok so I have 2003 13 spoke fxdx mags on my Dyna. Had hub drilled out for 1" bearings and sleeve and just got axle spacers to center the wheel. Propblem is now The caliper is not centered on rotor. The caliper is offset by a little over a half an inch. If I put caliper bolts on with 5 washers the caliper is centered on rotor.
Do I get spacers machined to push the caliper towards the wheel to center the rotor or is there a way to space the rotor to be center with the caliper?
Also if I get spacers made where would i get longer bolts for caliper to compensate for it being spaced.
I've searched every thread on this conversion and this step always seems left out. Any insight would be much appreciated
hey man check this thread. 07bobber is the guy you wan to talk to about this swap. he talks about it on page two or three.
https://www.hdforums.com/forum/dyna-...continued.html
rich24f73
03-18-2018 06:50 PM
masterblaster
05-07-2012 05:52 PM
