progressive drop in kit?
I got my drop in kit today for my 05 wide glide and about to install it had a question before getting to far into it. Do I need to drop the the forks all the way out of the triple clamps? I took the fork cap off and looks as if the top triple clamp is holding the spring down.
drop ins
yes, make hook using a wire hanger. There's a video on there site that walks you through the process.
Cover everything and use masking tape to prevent scratches on the tree/forks/cap. Careful jacking up the bike, just take the wait off the front tire and watch out when popping the cap off. I loosened the cap with the socket then covered it with a shop towel and held on. When cutting the PVC spacer I recommend measuring just a bit over. Then place a piece of sandpaper down on a completely flat surface (workbench) to sand evenly to correct size. Good luck take your time. Clean the threads and be careful when re-installing the caps.
Compress the forks once you have the caps off.
Easier to reach.
I never had to pull the tubes when I put them in or when I pulled them out and thew them in the garbage...
Edit: could not set the SAG at all with the Dropin lowering kit. Too stiff, they look cool, but are only meant for a bar hopper...
