08 FXDB with spark issue. motor turns and is getting gas. What would be the possible issues? Cleaned spark plugs they look good. Also bike is not charging the battery when i have actually got it to start. Would these problems be related? Any info would help.
Make sure the security system is ok, sometimes it could be keyfob out of battery. Of course check all fuses. Check coil positive terminal, should have 12v key on, then crank the motor and check coil negative trigger. The crank position sensor is common, do what I said and go from there.
