Remove Front Wheel 2009 FXDC
I have a flat front tire on my 2009 FXDC which I plan to fix later this week. I have ordered a service manual (today), but won’t have it before I fix the flat. I have researched as many old discussions as I could find on removing the front wheel and have printed out a really good write up by rdondes back in 2009 on a 2007 FXDC. I have a few questions that I hope someone can answer.
Are the instructions and details for removing the front wheel on my 2009 the same as a 2007? If so, most or all of my questions are answered in rdondes write-up.
I believe the torque setting on the axel nut of my 2009 is 50-55 ft lb, can someone confirm?
The axel cap is held on by two small round head bolts. I believe they are 5mm hex and the torque setting is 10 – 14 ft lb. Can anyone tell me if this is correct?
I read in rdondes write-up and several other discussions that you should replace the axel cap bolts with a ss bolts, as that is a weak piece. Anyone else agree or disagree anyother thoughts on this?
Thanks for any advice or information you can share. Emmo
