Rear taillight and turn signal install ??
Ok, I just purchased some new turn signals and a new tail light to install on my 2001 Dyna Wide Glide and got some questions. I did search the site first and got some good info but no answer for exactly what I'm wanting to do.
I don't want to hack up my original factory wiring and would prefer not to splice wires.
The front turn signals and headlight were a breeze.
For the rear turn signals I'm going from a 2 wire stock turn signal to a 3 wire, I know the extra wire is for running lights, but I've already got the Badlands load equalizer run/brake/turn plug n play module. When installing can I just leave one wire on the turn signals unplugged?
Also I would like to ditch the plug board (circuit board behind the stock tail light that plugs taillight and turn signals before going out to the 8 pin main harness).
Is it possible to wire to a 6 pin connector or would it be better to by-pass and remove it all together and go straight to the 8 pin connector and connect at the main harness under the seat?
The only thing is the circuit board combines all the grounds down to one ground going to the main harness?
Any options? I want everything to be plug n play so that I can go back to stock if I ever need to for any reason.
Whiskyjock
11-12-2017 10:18 PM
nchapa
Electrical/Lighting/Alarm
01-12-2017 04:40 PM
codykucich
06-28-2012 02:25 PM
