2010 streetbob front end.
I'm sure it's been covered but I couldn't find the answers I was looking for when I searched...I got a 2010 streetbob, and want to put a wide glide front end on with the 21" front tire. Any suggestions on years
That'll work, examples, suggestions etc basically looking for a lil more rake/stretched look with a lil thinner tire/ wheel. As long as it's safe and doesn't mess up the handling of the bike.
I did the wide glide conversion on my 06 Super Glide several years ago. I purchased custom made 3 degree trees, used my OEM tubes, HD WG sliders, and bought a WG rim from the classifieds here. The custom made trees were a pain in the ***. Fork stem was too long and not enough of it was threaded. Fork lock did not line up. If I had to do it again, I would just get the 06 later OEM WG trees through HD which are 2 degrees or I would go Accutronix. Wouldn't go more than 3 degrees no matter whose trees I used. JMO
Joe, my esteemed colleague I respectfully disagree. 49mm tubes started in 06. I was running 07 WG trees on my bob when I did it years ago. For the OP, HD discontinued the earlier trees at some point to make way for the new design in which the pinch bolts where recessed in counterbores. Not sure if they ever went to integrated risers or not on the WG.
