Rear Brake Rotors
Rear Brake Rotors
I've got a 02 Wide Glide that the previous owner swapped out the 150/16 tire for a 180/18. It has a custom brake on it to clear the 5" rim.
When I replaced the brake pads I found out the caliper is a 2 piston off the front of 4 wheeler. Needless to say it lacks in stopping power.
Performance Machine makes a 4 piston rear brake for rigid frame, and custom applications. I sent them a pic of my set up and they said it would work perfectly.
I'm wanting to replace the rear rotor while I've got the wheel off, but I'm wondering if I have a stock 02 WG rotor or if it's been frankensteined too.
I know it's a Harley rotor and the part number is 41797-00
Anyone know if this is the stock rotor that came on a 2002 Dyna?
