Loose brake and throttle cable bob?
Took the 10' Street bob out today and had a great ride. I noticed that where the clutch and throttle cables attach to the grip they seem loose or floppy. I can see the previous owner must have had different grips on and switched back to stock before he sold it because the torx bolts around the grips are a little scuffed up. Brake and throttle work fine but just by the feel of them. No noticeable issues just a observation- should the be fairly tight or looser?
All of the cables are adjustable. The clutch should have about 1/8" of slack and the throttle should basically have known if I remember correctly. The service manual has all the specs and procedures in it. If you do not have a service manual it is highly recommended that you get one as it will be just as important as any other tool that you have in your tool box.
Without going into a bunch of details, I know exactly what you mean, and this is normal. When the throttle is a rest, both cables will be a little "loose". Same applies to the clutch cable. There shouldn't be excessive slop, but all the cables will seem a little loose and you can move them some when they are at rest (no throttle and hand off the clutch).
Seems normal from what you describe.
No worries....if you feel there is too much slack in the throttle cable, you can always adjust, which is very simple.
