Installing Smart Security (Help!)
I have a 2014 Bob that did not come with the Smart Secuity, so I picked one up, (By the way, the new ones come with 2 fobs), and I need a little help. Pretty obvious where the Body Control Module goes....but what about the antenna? Also where does the siren go and plug into? If you have this system can you post some pics as to where they're located?
I'm going to attempt the install using some tutorials here...any tips? Thanks for all the help.
I assume your 14 SB is similar to my 07. Loosen the ecu cradle and pull it out a bit. You will see an empty slop below ecu. Put it right there and find the siren plug. For the antenna location, read pdf. Not sure what a BCM is, 2012 and newer I guess? Good luck!
https://www.hdforums.com/forum/gener...-its-loud.html
http://www.harley-davidson.com/en_US...ts/-J03842.pdf
I'm guessing that everyone went to Daytona! Lol!!! Wish I were there too!
Anyway, just found out this afternoon that my local Harley will install it and marry the FOB's for $41.00......so....can't beat that...especially since now it will be warrantied!!
