rear wheel pulley
smaller rear pulleys means more rear tire rotation per rpm. equaling higher top end and less rpm at cruising speed. but you sacrifice torque.
larger rear pulleys mean more torque. leading to better acceleration
reverse the above for front pulleys.
im pretty sure the stock pulleys are 32/66. theres a bunch of threads on the 30/70 mod so i'd assume the 70t rear should fit. if you only change one you may have to change the belt as well.
Guest
Posts: n/a
In a club that does a lot of riding, between that and work don't have a lot of time to pull mine off and get it done. will be easier to buy a stock one and have it done when i can.
