question about levers
03-15-2014, 11:02 AM
i want to order a set of new levers. when i change them out do i replace the bushing and pivot pin or can i use the original ones?
03-15-2014, 11:47 AM
Just replaced the levers on my bike. And I just used the old bushings and pins. From what I saw most levers do not come with new ones. Just make sure the old ones are in good shape.
03-15-2014, 11:50 AM
I just replaced my levers with black ones from eBay and they had the bushings in them. I wouldn't have replaced them if they didn't though.
03-15-2014, 12:15 PM
Just be careful replacing the brake lever. Very easy to break the switch.
03-15-2014, 02:01 PM
+1 with robbie13..fold a matchbook cover in have or something,pull the lever back and wedge it in there and release...then take lever off...i forgot this once and broke the switch trying to put lever back on...had to order new switch and solder it in...all cause i was rushing
03-15-2014, 03:38 PM
yea no problem reusing the pins
03-15-2014, 04:12 PM
When I installed my brake lever a couple weeks ago I just slid the switch housing down the bars. Didn't have to worry about the brake switch.
03-15-2014, 04:51 PM
Quote:
Originally Posted by
steve5109
the brake switch is in the housing. I don't get it.
03-15-2014, 08:18 PM
Right. If you slide the housing down the bars, the brake switch is away from the lever. Replace lever, and slide the housing back down.
03-16-2014, 07:49 AM
steve5109
Oh...my bad. I see what he meant.
doc308
Shovelhead
10-27-2018 01:01 PM
robbyville
03-23-2015 10:54 PM
Six16
03-10-2012 02:44 AM
jbg
11-06-2010 11:48 AM
NEONNIGHT34609
02-07-2007 12:00 AM
