Centering the swing arm pivot bolt
Hey folks
I plan on checking the alignment of my rear wheel and in doing some research I found something about the swing arm pivot bolt.
This sounds like something I would want to check first, before checking the alignment.
Anyone have any experience with checking this or problems with it?
Thanks...
Thanks...
What did the research mention regarding this. .? When I had the swingarm off and on, the bolt just slides through the transmission/swingarm, then a nut goes on and is torqued down. I'm not sure what centering could/would take place as everything only goes together one way.
I was thinking the same thing, that it would just go in one way, no adjustment.
Thanks!
