Fuelpak and quiet baffles.
Been doing some searching and can't really find a answer so maybe can offer some input. I have a 2008 street bob and the bike came with a SE heavy breather, vance & hines sideshots, and a fuelpak already installed. I only got to ride it a couple times before putting it away for the winter back in November. So yesterday I pulled it out and installed quiet baffles and then adjusted the fuelpak for the quiet baffles according to vance & hines. I took it down the road and back it was running really rough. It kept missing in first gear and idling rough. Rpm kept revving real high then they would get low like it was going to kill. Is this something someone else has experienced, is it something that will workout after a few rides? Any input would help. Also has a stage 1 download which I included in the fuelpak values.
Thanks
Thanks
Thanks
Thanks
The quiet baffles shouldn't make that much of a difference - can you revert to your old tune and see what it does?
I didn't put fresh fuel in, but I put some sea foam in the tank we I put it away. Didn't think to add more fuel stabilizer to it. I will give fuel stabilizer a try first then go back to the old values if that doesn't help. I wouldn't think the quiet baffles make much a difference either but the values are a lot different then the values for the stock baffles. Thanks for the replies
