Loose handlebar noise
The bars are mounted with rubber bushings so there is some play. If it bothers you there are poly replacement bushings.
Does it rattle all the time or when you hit a bump? Need more info.
The rattle could be loose tank bolt- put a wrench on it and check. Depending on how many miles it could also be the neck bearings being loose or worn.
