Help Needed. Crank Shaft Position Sensor Killing My Ride!
Hey guys,
Hopefully this is an issue others have had as well, and is an easy fix. My bike is a 2008 Super Glide Custom.
I keep having issues with getting a response from the crank shaft position sensor, and this is making my bike die when any throttle is applied.
I replaced the crank shaft position sensor about 7 months ago when this same problem occurred and it ran great until last weekend. Checked the diagnostics codes, and I'm getting the P0374 - CKP Sync Error code. I replaced the sensor again this weekend, so I know the sensor is good, but I'm still getting the same error.
Any suggestions as to what else might be a problem and causing that error?
