Turn signal module 69462-06A & CAN/BUS
If anyone knows the answer I would greatly appreciate your help.
I recently bought the Run, Brake, Turn signal module 69462-06A for my 2012 Dyna.. I have now realized with some additional research that the catalogue says I need the 69462-06C module... I bought the module from a private seller it is a N.O.S. peice and am hoping to avoid dumping additional $$$ at the stealer just to jump down a letter in the alphabet.
Are there that big of a difference(s) between the 2 modules? In appearance they look as if they're virtually identical.. Yeah I know my bike is CAN/BUS but is that the reason for the latest module change to the C series?
Can the computer "learn" this 06A module and be able to use it for its intended purpose?
