removing hand control switches...need help.
Old 03-27-2014, 02:30 AM
travism173's Avatar
travism173
travism173 is offline
6th Gear
Default removing hand control switches...need help.
Found a place to move switches but not sure what to do about the brake light switch thats in the factory switch housing. Any one have any ideas or know if anyone makes something to address this problem?
Old 03-27-2014, 04:42 AM
oldmisfit's Avatar
oldmisfit
oldmisfit is offline
banjo bolt on your caliper instead of the MC if you wanted to? or if your running duals up front use a pressure switch like the rear and tuck it under the triple tree? or not run one.
ltr Pat
Old 03-27-2014, 06:29 PM
travism173's Avatar
travism173
6th Gear
Banjo? And what do you mean bolt on to my calipers? Not sure im following you? Im running a front break but I dont wanna run a wire down my fork for a pressure switch like the back.
Old 03-27-2014, 07:15 PM
coot58's Avatar
coot58
coot58 is offline
brake light banjo bolts to replace the one in the reservoir,wires go to brake light,not down the front end if thats what you mean..dennis kirk sells them.
Old 03-27-2014, 08:19 PM
oldmisfit's Avatar
oldmisfit
For the triple tree move, place this in line
Brake line junction box deal
For the caliper move place this in line
ebay search for banjo bolt pressure switch
ltr Pat
Old 03-28-2014, 12:24 AM
travism173's Avatar
travism173
6th Gear
Oh ok I think im on the same page now. so that banjo thing will go where the line comes apart under the triple tree? I think its a 2 piece brake line??? And that has a pressure switch in in instead of the one on the handle bars
Old 03-28-2014, 12:54 AM
travism173's Avatar
travism173
6th Gear
Dude thanks alot....I found my answer...I was looking on that web sight to look into that thing and saw I could use the lil banjo bolt thing and use one of the plane brake trees...and itll probably only cost me around 30 bucks...cool deal. ..I like that website to man alot of good stuff thanks
Old 03-28-2014, 07:13 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Would something like this work? You could take the existing wires running up the bars to the existing brake switch and splice them into the wires on this switch under the tree where the brake line is mounted and just secure the wires to the brake line from the banjo to the tree.
http://www.ridersneeds.com/motorcycl...%3DPBL992-32CH
Daves'81FLHS
Shovelhead
04-08-2016 11:46 AM
Cory81
12-25-2013 02:34 AM
hsmagana
07-18-2012 02:19 PM
fradessa
12-12-2010 09:38 PM
Green Machine 04
10-05-2010 02:34 PM
Quick Reply: removing hand control switches...need help.
