Front Brake Lever/Light Issue ??
Brake light stays on from the front lever-took it apart-the little plunger that activates the light is fully out-i can push it down fully with a screwdriver-can pry back the lever enough so the brake light WILL go off-but put back as normal-the plunger seems too far out and keeps the brake light on-is the plunger bad? What's the problem?
2011 Superglide
2011 Superglide
Could be the v shaped clip...have a look at this post:
https://www.hdforums.com/forum/7378764-post4.html
