plugging the bung..
Old 03-30-2014, 06:20 AM
PaiN's Avatar
PaiN
PaiN is offline
Default plugging the bung..
Don't get all excited pigs.....exhaust bungs.
I'm getting a new V&H exhaust with 12mm O2 sensor bungs, I don't need to install the sensors with the tuner I'm using.
Any one know what bolt size/thread to use to plug the bungs?
thanks
Old 03-30-2014, 06:26 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
If your bike is injected...taking the sensors out of the loop is kinda stupid.
It's probably M12 x 1.25. You can probably get those at your local auto parts store. I ran O2 plugs on my Thunderheader when I ran a Power Commander III. They were M18 x 1.25. I got them at the auto parts store. A couple bucks each, if that.
TIP: Use anti-seize on the plugs.
hell hound's Avatar
hell hound
hell hound is offline
Are the pipes used? I would have thought they would come plugged.
I completely removed my 02 sensors too
Old 03-30-2014, 09:04 AM
PaiN's Avatar
PaiN
PaiN is offline
New pipes, do they come plugged? This is my first new hd exhaust
Old 03-30-2014, 09:39 AM
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
Should be M18-1.5. At least was on mine.
Old 03-30-2014, 11:26 AM
maddghost's Avatar
maddghost
maddghost is offline
That means you will have plenty of time to call V&H, find out what's in the box and what isn't and then go from there.
Old 03-30-2014, 01:36 PM
SC-Longhair
Model year 2012+, they were switched from 18mm to 12mm bungs.
Old 03-30-2014, 02:29 PM
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
My bad. Now I know. Didn't see his year model in sig or post.
Old 03-30-2014, 02:33 PM
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
And heaven forbid they would keep something the same size!
Old 03-30-2014, 03:17 PM
PaiN's Avatar
PaiN
PaiN is offline
I can't remember where, but I thought I read that the HD oil drain plug fit the 12mm exhaust bungs......I was hoping when I posted this question it was "common knowledge" and someone would just chime in and say go get a couple of drain plugs......guess not.
Quick Reply: plugging the bung..
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
