Disconnect or ?
Disconnect or ?
Fellas,
Got to leave my ride for about a week and a half, no feasible way of putting it on a tender. Looking for advice on whether or not I should disconnect the battery or do you think it will be fine? I do have an alarm, which is the reason I am wondering if the battery will be drained in that amount of time or not.
Thanks for the advice!
I would make sure it has a good charge on it (ride it for an hour or so on the highway) right before putting it up. If you don't need the alarm to be armed, then disconnect the frame ground from the battery. If your battery is good and not too old, it should hold a charge for 10 days just fine. My battery is around 16 months old and I ride regularly and it has sat in the garage for as long as two weeks or more connected and without a tender on it and still cranked up just fine.
Fellas,
It takes at least 4-6 weeks before the batteries discharge significantly. It is more of an issue in cold weather.
You will be fine...the alarm drain is pretty insignificant.
Well fellas, got back a day early. Kept my fingers crossed that my bike was where I left it first of all, and it was
Fired right up, no hesitation at all. Still dont care to do it that way, would rather leave it on a tender, but at least now I know I can leave it for a couple weeks if I absolutely have to.
