Rear signal relocate with Hogrida Lay Lo license plate bracket??
I've got the Hogrida Lay Lo license plate bracket, which I really like. I'm thinking about adding saddle bags which will require me to relocated the OE rear signal lights. I've seen some relocations where the OE signals are relocated to a bar that runs under the license plate frame. Has anyone had any luck using this type of relocation with the Hogrida license plate bracket? I suspect that the bracket is too low to run anything under or behind it but I figured I'd ask.
Thanks.
Thanks.
I've done exactly that...
The bar is the Bullet Rear Turn Signal Bar (clicky)
It's meant for the FL family but a couple of holes in the fender and a little grinding of the bar and you're set… Lot's of info available if you search for it
Street glide signal bar! Here's my write up too. https://www.hdforums.com/forum/dyna-...turn-sigs.html
wyotana
05-31-2014 12:06 AM
