Fork oil. 2 quarts ???
04-04-2014, 05:38 AM
I'm having to order some Amsoil 10w fork oil. Will 2 quarts be enough. 2011 Wg. I'm doing the Rsd / traxxion / Intiminator swap. I just ordered a service manual but have not picked it up yet. Thanks.
04-04-2014, 05:55 AM
04-04-2014, 05:57 AM
Yes, you should only need about 8-12 ounces in each. You will have spare... Should be changed about every 20000-25000 miles.
04-04-2014, 06:08 AM
Oh, yeah. Don't be surprised if one side, (brake) is dark brown and the other is clear. I haven't seen a good reason posted as to why, but my guess is brake heat.
04-05-2014, 06:51 AM
Never did the single disk change, Both my Dyna and the FLHTC is both nasty...
04-05-2014, 07:40 AM
Two quarts will do it. I filled mine up to four inches below the top of the tubes and had just a little oil left in each bottle.
04-05-2014, 02:48 PM
Quote:
Originally Posted by
Notgrownup
Those are the recommended refill amounts for the 41mm forks. 49mm is 29.6oz stock.
04-06-2014, 07:20 AM
SC-Longhair
Damn that's a lot compared to my bagger and my Dyna... Didn't know there was that much difference...Thanks V.
04-06-2014, 08:02 AM
SC-Longhair
Maybe the WG forks need more because they are longer but the fatbob 49mm forks require 26.6 ozs.
04-06-2014, 08:39 AM
Not sure how much mine took. The SM tells you to measure the distance to the oil, so that is what I did. Pretty simple really.
roaddr
12-19-2012 03:05 PM
dazza336611
12-19-2012 02:12 AM
Steel Steed
07-09-2012 06:59 AM
KumaRide
07-07-2010 11:26 PM
ChromeJunkie
06-15-2009 10:35 PM
