Fuel Line Leak - Help
Old 04-10-2014, 07:44 PM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
Default Fuel Line Leak - Help
Just had the paint redone on my 06 FXDI. Got it all back together this evening and noticed a leak. The line from the bottom of the tank to the intake is leaking at the quick-connect. Disconnected it and pulled a piece of o-ring out of the female fitting that screws in the tank. This is not the o-ring where the fitting threads screw in the tank. I guess there is one either inside the female fitting (#8 below) or on the male fitting (#21 below). Checked the parts manual and o-ring is not listed. Not sure what I need to replace, the female fitting or the male.
Anyone else been through this who can help me out?
Old 04-10-2014, 09:14 PM
monster715's Avatar
monster715
monster715 is offline
This happened to me after paint as well. I bought a new female fitting , but there is a little o ring in there you can replace. Less messy and a lot cheaper to do it that way
Old 04-11-2014, 05:05 AM
trek51's Avatar
trek51
trek51 is offline
Change the O ring in the female end. Need to use a mirror and a dental pick to look inside and pull the old O ring. Use a little grease on the O ring when you re-install, makes it easier to keep it in place.
Old 04-11-2014, 05:28 AM
Tat2u's Avatar
Tat2u
Tat2u is offline
Yep exactly this !! make sure you do use the grease as the o ring can chop out very easily if you assemble it dry. its the same size o ring as used on all the oil drain plugs
Old 04-11-2014, 06:02 AM
jmpancoast's Avatar
jmpancoast
Thanks guys. Going to pick up a 11105 o-ring today. Based on other searches, also saw some who said to use 11273 o-ring. Going to pick up one of these too.
Don't mind the expense of the check valve, or the labor to change. Just the bike has been pulled down since February and its time to ride. Don't want to have to order the check valve and have to wait.
Old 04-11-2014, 08:46 AM
jdub099's Avatar
jdub099
jdub099 is offline
I heard this O-Ring works:
Amazon Amazon
Old 04-12-2014, 05:15 AM
jmpancoast's Avatar
jmpancoast
Originally Posted by jdub099
Thanks jdub. Can't believe John Deere goes up in ya deeper than Harley does.
John Deere Original Equipment O-Ring #R26286
by John Deere
Be the first to review this item
Price: $7.95 & FREE Shipping
In Stock.
Ships from and sold by Hartville Tool.
giarcmo
02-20-2023 08:15 PM
Kaycee
Carburetor Related
10-08-2012 09:55 PM
ric306
11-18-2010 09:10 AM
beemer737
Exhaust System Topics
08-25-2010 05:53 PM
bigstevex4
07-25-2008 10:06 PM
Quick Reply: Fuel Line Leak - Help
