96 vs 103 Wide Gldie
Hey all! I am a first time poster here so I am not sure if this has been discussed before so I am sorry if it has.
My questions is for those that have ridden the 96 and 103 Wide Glide. I am looking at buying one or the other. The question comes up because I can get a good price on a 2011 WG which has the 96 or buying something 2012 or newer that comes with the 103. Is it worth the extra money to go for the 103? I would do a Stage 1 on either as well.
Thanks for the feedback!
You have to REALLY look ahead and see where you want your build to be at.....
If you will NEVER bore your cylinders then I would get 103, but if you're gonna go bigger there is no point spending the extra coin for something that you will tear apart and make bigger than a 103.
Like reindeer said a 96 & 103 can both be built to a max of 107 (w/o longer rods). If you are getting a smokin deal on 96" go for it.
personally im fine with the 96" on my fatbob (once i got off the stock map). for me suspension upgrades would be a better place to spend the money than a 103 or 107 upgrade. now if i happen to have the money sitting around after the suspension upgrades......
