Inner primary bearing seal
I'm pretty sure that seal is leaking and the baker bearing/ seal has been recommended, I just want to be sure I'm buying the correct kit from baker. PN 189-56 is listed on their site for up to 2007 but I'm pretty sure that's the one I need (08 FXD). Also I'm wondering how this thing could be leaking at 20k and damn near being ridden everyday, what's could be causing this? Something else I need to look into? I'm going to put the bike on the lift tomorrow and make sure that the seal is the source of the leak, but I'm sure that's it.
Hi,
I just dealt with same thing FXDWG 2010, 32000kms, i thought it just the seal as when i measured the inner bearing race it was close to spec but it has to be about 2mm from main gear shaft
The inner primary bearing was fine, replaced the inner beAring race and seal and installed with Heartland tool and all been good since
I think there a change in 07+ bikes so baker and S&S dont make those parts
Thanks
Mirrmu
Thanks
Mirrmu
Hi,
Thanks
Mirrmu
Thanks
Mirrmu
Hi,
I think the manual spec is 2-3mm from main gear shaft, when first had a go at mine i measured distance and it was around the 3mm so i left it thinking just seal, replaced seal and it leaked agin but less than first
In the photo it looks close, measure it, on second go i went with about 2mm off the main gear shaft, put a new race on and new seal, no leaks
Thanks
Mirrmu
Thanks
Mirrmu
Thanks for all your help mirrmu I really appreciate it man! I ended up sending this same pic to my good friend who's a hd mechanic and he said the race looked like it was good. I didn't end up replacing the bearing since the race was staying and just replaced the seal which was for sure leaking. It's all back together now, I upgraded to the SE clutch discs and spring while I was in there. It's only gotta hold for about another 10k til next winter when the motor comes out!
I just replaced my seal last night. I have 44k miles on the bike and it's been giving off a drip or two after a ride for the past 15k miles. this last ride I did about 200 miles it finally started spitting out more oil so it was time. The actual seal change took less than 5 minutes.
