TruWrapz installed
Thanks. I think I'll do it. You got the amber ones, not the "dynamic" or whatever that have daytime running lights (DRL) that turn off and go to amber, right?
ya mon do eet!!
yup the regular amber ones... they are running lights but they're amber as running and just blink as sigs
Sorry I know this is an old thread but this was the only things I could find that could help..
iDodgimus, how did you wire up the HD LED Mirrors and TruWrapz? I literally just bought the same 2 items and can't figure out where to start. I want to get rid of the stock signals obviously but the instructions for both don't really help in my case. The wiring harness provided is pretty confusing too
Any help would be great appreciated
don't be scared, the y-harness is way easier than the instructions would have you believe...
i did it one at a time, mirrors first then wired the leds into the connector that the stockers use, so from the perspective of the wiring it all looks stock.
the y-harness is essentially a splitter, plugs into the bike's harness and splits it so you can plug in the stockers and the mirrors. take a look at all the connectors and see which ones match and do a dry run - it should make sense once it's laid out in front of you. it really is amazing how complicated they made this part sound.
once i had the mirrors and stockers hooked up i snipped off the stockers close(ish) to the connector and spliced in the module and the leds.
there's probably an easier way to do it, but this made sense for me
good luck, post up when you're done.
