Stupid taillight!!!
Stupid taillight!!!
so after riding abut 500 miles this weekend on my way into the office I notice my right rear taillight/brake light was loose. So I tried to tighten it up and the threads inside the tail light housing are stripped.. have no idea how it happened but now its time to fix it.. should I just get an OEM housing from Harley or is there an aftermarket one? been searching but not sure if some of the ones I found on the net will work... any help guys??? Harley wants 60 bucks for the housing?
I might just say screw it and get these, http://www.jpcycles.com/product/306-966 but intil then I cant ride the bike because the bolt will back out and hit the tire...
On mine, the housing is chromed plastic with a metal tab at the bottom for the nut to set in. You can try some epoxy, will hold up until you need to remove the housing.
I've gone through more than a few of the aftermarkets ones, they are all cheap plastic and I ride on rough roads so they tend to give in easily.
well i just bought a turn signal from harley, but i will be running one of these set ups http://www.customdynamics.com/trufle...d_lighting.htm (scroll down on the page, its under the fender and it has stop tail turn lights, its gonna run me about 70-80 bucks shipped)
