progressive 444
Old 04-14-2014, 01:05 AM
2013superglideseattle's Avatar
2013superglideseattle is offline
Default progressive 444
Installed progressive 444 today on my bike. Big improvement is the weight of the bike. It feels like I have an empty gas tank all the time. Cornering is much smoother than stock.
As far as riding on pot holes and rough roads, I need more time to evaluate.
More results to come. keep you posted.
I weight 165lbs.
Old 04-14-2014, 02:32 AM
boro's Avatar
boro
boro is offline
Glad to hear you had a good experience.
That's pretty interesting. The standard spring is set for 210 lbs. I weigh 195 and feel they are a little too much, maybe because I'm comparing to Ricors. No question they are an improvement over stock, and less expensive than Ricor, Ohlin, JRI, etc. My biggest problem is the rebound, which is supposed to be the improvement the 444 has over the Ricor valve. I hit a little too hard coming off some bumps that aren't that big, which I thought may be the spring weight.
Is the preload adjuster all the way up? Looking forward to your update.
Old 04-14-2014, 04:27 AM
Chase1961's Avatar
Chase1961
Chase1961 is offline
I put a set of 444s on and went for my first ride Saturday. They are a big improvement over OEM shocks. Ride was much smoother. Can't really comment on handling, as winds were 20+ mph.
Old 04-14-2014, 06:37 AM
valhalla-77's Avatar
valhalla-77
valhalla-77 is offline
Have to say that these shocks are good as öhlins,no doubt! Had öhlins in my old dyna and night rod,and 444 have very similar performance. Very good shocks,when you ride them in good!
Of course theres no other adjustments than preload,but these were well balanced! Totally worth of money!!!
Old 04-14-2014, 08:02 PM
missedem's Avatar
missedem
missedem is offline
Once you get them adjusted they ride great. Mine like to be tight on the adjustment . I turned mine down about 3 and a half turns . Till 3 adjustment lines are showing and the rebound is much better. I also put progressive springs in the front and that really balanced things out. Made a very big difference to me. I am 185 lbs. and always ride solo.
Clammy
07-13-2021 05:10 PM
kami
01-21-2020 05:35 PM
Streetrunner
04-22-2019 11:38 AM
XARAN
01-05-2012 09:55 AM
Fast FLHX
03-26-2008 12:15 AM
Quick Reply: progressive 444
