Speedometer trouble - 2000 Wide Glide
Old 04-15-2014, 05:44 PM
andrew886's Avatar
andrew886
andrew886 is offline
Stage II
Default Speedometer trouble - 2000 Wide Glide
So took the bike out this past weekend and everything ran great except midway home the speedometer on my 2000 Wide Glide started intermittently working. The Needle would drop to zero, then kick back on minutes later for a few seconds, then stop working again.
When at home I ran the diagnostic mode by holding in the reset button and turning on the ignition and found comes d01 and d02 had been triggered. I cleared them, and found d 01 trigger immediately again. Both of these codes state there is a low end range speed sensor issue and high end range speed sensor issue.
My question is, has anyone dealt with this before, and if so what was the solution? If not, would you just order a replacement speed sensor, or is there some way to clean or recall rate it (external housing is clean and free of debris)?
Any thoughts or advice would be greatly appreciated.
-Andrew
Old 04-15-2014, 06:21 PM
TexasScooterTrash's Avatar
TexasScooterTrash
TexasScooterTrash is offline
Received 1,200 Likes on 736 Posts
When you clear the error and it comes right back, there is a problem. Speedo sensors are cheaper than speedometers. Go ahead and change it.
Old 04-15-2014, 06:59 PM
Robtarra39's Avatar
Robtarra39
Robtarra39 is offline
Try removing the speed sensor and give it a cleaning, cheap and takes no time before buying a new one, crud can build up on them over time
Old 04-17-2014, 07:52 AM
andrew886's Avatar
andrew886
Stage II
Thanks guys will give it a good cleaning, and if problem persists I'll go ahead and change it. Never installed one before, any tricks/calibration that needs to take place or is it just plug and play?
Old 04-17-2014, 08:16 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
+1 on cleaning the speed sensor. It's located at the r/h side on top of the gear box, item # 39 in this diagram.
A new one is just plug and play!
vacguy
06-12-2010 12:47 PM
Big_cityreb
07-13-2009 08:25 PM
msmith
07-05-2009 03:25 PM
kens3313
03-07-2007 03:07 AM
FreddyP
07-07-2006 11:42 AM
Quick Reply: Speedometer trouble - 2000 Wide Glide
