Positive terminal melted...
Hello all,
Bike wouldnt start on tuesday morning, had been a little sluggish to start on monday, so just thought my battery had finally given up the ghost [its the 8 year old original]....however when I pulled it out last night I discovered that the positive terminal has actually melted a good 8mm back from the face of the battery.
What is the most likely cause of this? Had the rotor/stator replaced in october, is it possible battery was put back in with a loose connection, could that cause enough heat to melt the terminal?
My concern is putting a new battery in only for the same thing to happen again, cant see any damage to the leads and will start again since i cleaned it up a bit and tightened the connections back up, even with the 8mm missing off the + terminal.
Also can anyone recommend any alternative battery for an 06 fxdci? As local dealer looking £153 to replace like with like...
I saw this on my brothers bike last year. 2000 FXDL. The only thing I could figure was a loose terminal causing it to arc and melt the post. The seat had burn marks on the bottom and the seat pan was fiberglass is it did not cause the issue. He got a new battery and made sure the cables were properly tightened and no problems at all.
Received 47,745 Likes
Hello all,
Not sure if your battery is AGM or not, but consider an AGM battery as a replacement (sealed, no vent tube). HD batteries are made by Deca. In the US they are sold under various names in auto parts stores at about 1/2 the HD price. Not sure where you might find them locally, but try searching. Failing that, any good AGM battery should work (Yuasa, Interstate, Lucas??). Not sure what's available to you in Ireland.
PaGuy610
03-22-2018 05:56 PM
brenth
09-12-2011 06:32 PM
