Batwing Fairing for a Dyna
I have a 2001 Dyna Super Glide T-Sport. It has a stock small faring with a 4 point mount. I'm trying to find out if anyone knows of a mfg that makes a small batwing fairing, outer shell only that would fit the T-Sport utilizing the existing 4 point mounts that also doesn't require removing the existing stock tach and speedo. I'd be happy if it used the existing brackets from the stock fairing. I've seen a couple but they are in the $700+ range and include an inner shell with speakers and a radio. I have seen a shell only but with no mounting brackets or hardware plus it required removing the gauges. Anybody heard of what I'm looking for?
Hoppe Vanillazilla
http://www.jpcycles.com/product/ZZ77517
Search Ebay, I found one that goes for about 250 depending on the bidders but it has an inner panel. You could modify this to fit around your existing setup.
Check out dead center cycles. The Road Captain fairing is a smaller batwing designed for Dynas and Sportsters. You can get it with or without the inner fairing. Price starts just under $600. Check it out.
https://www.deadcentercycles.com/fai...ad-captain.php
I just put a M/S batwing on my FXDI. I was really worried about it clearing the speedo. It cleared better than expected, so I would think it would clear the tach and speedo setup, if its a fastory setup. I ordered the brackets also and really like them, the brackets are adjustable up and down and you can adjust the tilt on the fairing aswell. Haven't bought a windshield yet, I had a shorty left over from my EG which I adapted and so far its working well. I am very happy with the fairing.
