Power Vision Map Needed
Guest
Posts: n/a
If you are running the RR 1D5250 pipes like me, I had to manually tweak the 20 and 27 MAP columns on my AFR table and manually adjust my decel enleanment table to get rid of decel pop. I think Autotuning will help but short pipes are tougher to get rid of decel pop IMO.
Guest
Posts: n/a
I adjusted the fuel decel in the quick tune to 4 and the decel area spark to 5 (5 is the max mine wont go any higher) I am not to familiar with adjusting anything in the AFR table. How did you know that table 20 and 27 were in the decel area? What did you adjust from and too? Thanks.
and their is a issue will popping. when you are down shifting with the throttle closed coming to a stop like most people do the adjustment is different. they want you to go into the afr table in the first column and adjust there. lets say you notice the decel occurs from 3000 to 1750 rpms. and the afr is set to 13.0 than add fuel by changing to 12.8 in the cells from 3000 to 1750 and they also want you to add 3 to the timing area also. this pertains to builder builds like ours if the motor is basic stage 1 the best method is to use the quick tune feature on the PV. hope that makes sense.
Guest
Posts: n/a
alan just got off the phone with two different techs the decel enleanment feature is only used when u are slowing engine rpms down slowly with the throttle, like if you are cruising at 3000 rpms and you slowly drop to 1500 rpms
I ran about eight or ten auto tune sessions and still couldn't stop the decel pop. Sent my tune to dynojet and they made some changes. Loaded it and all was good. Now I get no decel pop at all. Bike runs mint. Haven't messed with the tuner for a while now. I never went in to even see what changes they made. I just know the bike runs great.
Ok I found the AFR Table and made the changes inside the 1700-4000 RPM range. The set fuel was 12.5 I changed that to 12.3. The trimming you say to add 3 to is this in the quick tune potion of the PV or is it in one of the manual tables accessed from a WinPV program? Thanks.
We need to get some charts in here to help the SCPO, let me go dig....
Before I did my engine build this was my AFR chart for a Stage 1:
It is in lambda, so multiply my numbers by 14.6 to compare to what you are doing.
