help me please!!
help me please!!
My '94 dyna is spewing oil out of the breather tube until my oil light goes on. We are talking a whole quart in like twenty minutes of idling. The only thing I've done to it this winter is paint it. So I'm not sure why it would do this now could the oil filter be clogged? I'm lost Please help!
What type of oil filter ?????
Do a search on " EVO ball valve in oil pump " for homework. An ounce of oil from all the drain down sitting over the winter will look like a gallon. You also say idle for 20 minutes till oil light goes on. That could be from overheating. Never idle an air cooled motor 20 minutes. Put the correct open micron filter on it like Harley designed it for. (that could just be a OEM Harley filter if they still make one since I think it is 10 micron--most aftermarket are 5)
Probably a stupid question ????
This is probably a stupid question, but you did remove the plastic oil filter protector that K & N puts on there filters....??????
Just thinkin maybe a few beers in to it and forgot to pull the plastic protector.
Hope you get it figured out...............
