fatbob rear wheel bearing installation
Awesome thank you. So this is what I did for the front, can you correct me if im wrong before I burn up my bearings rim or new tire. I seated both bearings flush with the outside of the hub. Then I pushed in the left bearing untill the inner rim spacer was slightly contacting both bearings.
Is this correct? Should I do the same with the rear? (Opposite side though)
I have a manual but it dont tell ya squat.
Thank you!!!
Thank you!!!
Thank you!!!
Thank you!!!
I'm assuming you have the right tools to support the inner/outer races of the bearings so as to not side load the bearing during install.
On the rear you press the right/rotor bearing until it contacts the machined lip, then insert spacer/sleeve, and then press the left bearing until it contacts the spacer/sleeve. Don't overdo it on the 2nd bearing, ie you shouldn't be exceeding the axle torque (~60ft-lb for front and ~90-100ft-lb for the rear).
