PowerVision tune?
PowerVision tune?
I have a 2013 Fat Bob with a cobra intake, and V&H big shots exhaust. I use the PV to auto tune the bike and it works well!
But?!
I've noticed that the bike doesn't hold the tune for very long? I keep needing to reflash the custom tune, after about a month or so??
It's almost like the bikes ECU is doing it's own adjusting to the tune and trying to return it to stock settings? Which makes the bike start to run rough.
Then I need to re-flash the custom tune and the bike runs great again!!
Anyone else have this experience? Is there a way I can stop this from happening? Or is flashing the tune periodocally something I'll have to live with????
But?!
You might want to contact the guys at Fuel Moto and ask them - sounds strange to me that it would do that as you have to do the whole bit of accepting the new flash, turn off the key to reset it....
I'd be interested in hearing a follow up after you talked to them and figured it out...
Hopefully it's an easy fix and I won't have anymore issues.
I got an answer from Powervision. They said that the bike's ECU is adjusting the "Trim" and "fuel" settings not the tune itself. There's a way to turn that function off in the "tools" setting of the PV. I'll check it out when I get home later today.
I am with Scott on this one, it could be a memory lost.
I don't think I understand your question, what do you mean by keep flashing ecm? It sounds strange to me. I never had problem with Power vision, not even a proper dyno tuned and she runs like a top. Thank to Fuelmoto
