2010 wide glide starter problems
Old 04-25-2014, 12:13 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
Default 2010 wide glide starter problems
Before I start pulling things. Went to start our 2010 wide glide, ss106. It started turning over like normal. Then it stopped cranking the engine. Now when I hit the starter I get a loud knock and that's it. No click, a knock, I can feel it hit by putting my hand on the primary.
Any ideas before I start on it.
Thanks in advanced.
Old 04-25-2014, 09:52 AM
mattVA's Avatar
mattVA
mattVA is offline
Loose connection and it's not getting enough juice? The starter itself is freezing up? Sounds like you're gonna want to remove the starter and bench test it if the wiring and battery are good. I have the instructions from the electrical manual somewhere.
Old 04-25-2014, 04:05 PM
dirtdobber's Avatar
dirtdobber
Battery is good, checked it already.
Kinda sounds like the drive went out too far and is hitting something in there.
I'll pull the primary later and have a look first then pull the starter.
Slope
04-08-2018 08:36 PM
Hosmtony
10-15-2016 07:07 PM
Streetrunner
05-20-2014 08:55 PM
mang0
07-15-2012 05:08 PM
wildbillXIII
10-22-2009 10:40 AM
Quick Reply: 2010 wide glide starter problems
