Newbie on a streetbob with alot of questions
Hey guys,
Bought a second hand 2010 street bob 2 months back.
Need to be put up to speed about
1) What is a rake? can i rake my stock forks? Current fork is raked at 21DEg.
With invert fork. item very unstable & forks did function as norm shocks... please shed some lights.
2) is there a rake thick forks on the market that is does not effect so much stabilities issue as my current ones.
3) is there any chance on the market to input wider rear & front rims for my SB? & what are the items that i'll need to mod.
4) custom tanks?
Thanks peeps.!!!
4) custom tanks?
Thanks peeps.!!!
Hey guys,
4) custom tanks?
Thanks peeps.!!!
4) custom tanks?
Thanks peeps.!!!
You could put Wide Glide trees on it. Depending on the year, the trees have 1 or 2 degrees of rake. In fact, if you put the entire WG front end, it will help the wide tire option.
I don't know much about the wheel change. I know the Street Bob is somewhat limited at the rear. You can go one extra width size on the tire if you trim the belt guard (or remove it.)
The WG front will allow a big change in wheel and tire size. You'll need different spacers, but I'm not sure where to get the information.
Good luck la.
Good luck la.
Hey guys,
4) custom tanks?
Thanks peeps.!!!
4) custom tanks?
Thanks peeps.!!!
Can you post a picture of the bike? I think a little is lost in translation here, but if I understand the bike has an inverted fork on it now? Maybe the previous owner put an aftermarket fork on the bike, and it changed the rake/trail so it handles poorly now? A stock Street Bob should feel pretty stable.
Good luck la.
Good luck la.
If he were to go with a complete Wide Glide front end (trees, Legs, 25mm axle and wheel/bearings), then he can use his Street Bob spacers, they are the same part number. My bike currently has Fat Bob trees (same rake as Street Bob), Street Bob legs, spacers, brake caliper and rotor, with a Wide glide hub/25mm bearings laced to a 21"x3.25" hoop on a Wide Glide/Fat Bob 25mm axle.
Hey Guys,
My bad..
What i meant is, i've bought a 2nd hand Streetbob of which, the previous owner had installed an aftermarket fork that is rake out.
Hence this cause me stability issues.
Do you guys have any suggestions on how to stabilize it & what is the minimum rake angle to prevent any stability issues?
On another note, i planning to re-instate the original forks but wish to have that "rake" look.
My question is that, is there any ways that i can rake my original forks?
alternatively , any recommendations for an aftermarket fork that is rake & won't caused an stability issues?
My bad..
The two ways would be raked bearing cups for the neck stem bearings, easy option but I think they look a bit off as the bottom triple tree ends up sitting a bit lower than stock...
Or.. Use wide glide trees which will give you extra rake but they are wider so will need new axle, axle spacers and fender spacers.
Both options will lower the front too which may be fine with you or you might have to get longer fork tubes.
Hey Guys,
My bad..
My bad..
