Inner primary changes
I am getting ready to swap my fat bob to mid controls. I picked up an inner primary, part 60790-06A for cheap
After some research, I realize that this has been superceded two times and the current number is 60790-06C
Anybody know the major differences? Should I just bit the bullet and get the newer part or is it just a bearing change or something that I can address on the cover i have.
What years the bike? I just did mids in my 13 bob and I used the same inner just had to drill a 1/2" hole where the linkage goes through...very simple it has the linkage tunnel cast into the cover already just isn't drilled all the way through make sure you grease the linkage where it goes through
I am getting ready to swap my fat bob to mid controls. I picked up an inner primary, part 60790-06A for cheap After some research, I realize that this has been superceded two times and the current number is 60790-06C Anybody know the major differences? Should I just bit the bullet and get the newer part or is it just a bearing change or something that I can address on the cover i have.
Anyways, just to be safe I had the dealer install new bearings in the casing.
If you're buying new get the newer part, if used just replace the bearing.
Yeah, It looks like this is the breakdown:
60790-06 is 2006 Dyna with the old (bad) bearing
60790-06A is the part for 07/08 Dyna
60790-06B is 09/10 Dyna
60790-06C is 2011+ dyna
The replacement for A/B or C is 60790-06C
Not sure what the revisions are but they are all interchangeable, I'm just going to replace the bearing on the 60790-06A that I have and use it since I got it for $45
