transmission based oil filter mount leak
I have a 86 fxr with a delkron transmission upgrade that has the oil filter mount bolted down through the rear of transmission just infront of the swing arm.I parked the bike for the winter was all perfect,started it a while back and started puking oil.I couldnt find the source until today i noticed it looks like the leak is from the top of trans where the oil filter mounting bolt runs through the transmission itself.All the lines are tight no leaks but the top of transmission has a puddle around the mounting bolt.Could the actual mounting bolt be the cause?Any help appreciated
