Fuel gauge wiring on 2011 fat bob
I'm trying to work out how I can get my fuel gauge in my multi display speedometer to work alone. I have removed the tank mounted fuel gauge and now the central multi function speedo/tacho/rev counter/ gear indicator/fuel gauge is showing empty in the fuel gauge section. Is there an easy way to sort this? Join wires together etc? Many thanks in advance. Jim.
Easiest is to remove the circuit board from the fuel gauge and leave it under the dummy cap with some insulation to keep it from rattling. You can read more here:https://www.hdforums.com/forum/dyna-...k-is-full.html
