Vibra-Technics Dyna mount?
If you want pics from a diff angle mounted let me know. I have the evo mount but it's similar. Same basic design just a diff top plate and you can see the washer and bolt. On the tc version it's enclosed
This is the side you can see the stabilizer
Yeah, I'm pretty much aware of all the different H-D mounts up close and personal except for the newer streetglides that are apparently using two up front. I like to know if the actual Vibra-Technics has a one or two piece isolator (rubber) and by knowing the design I could tell how much fore/aft movement it's helping to prevent, few other things. I built a custom sportster frame and mounted the motor using Dyna mounts back in 89. I recall when the original Dyna first appeared reading the factory write-up claiming the mounts were adapted from helicopter rotor blade anti-vibe technology? I've never verified it tho, just a FYI...
this Vibra-Technics mount most closely resembles the front mount in my 04 Buell XB12S, but the Buell's is in tension and will come apart with age and/or if you are a wheelie addict, the V-B is in compression so shouldn't be a problem there, but doesn't seem to have as much fore/aft control (from what I can see) as compared to my Buell, and the Buell has no locating linkage in the vicinity of the mount either... just mostly really curious about how it all goes together.
Everything you want to know can be found here: http://www.harley-davidson-hangout.c...velopment.html
Including the pictures you wanted to see
