The Evolution of my monster :)
Ultima Inverted Front
Ultima inverted Front end ... link to the one i have is below
www.ultimaproducts.com/58mminvblnd.html
mine is a 6 over if you decide id suggest a 0 or a 2 over max
i had to weld a 2 inch square steel tube on the bottom of my kick stand with the 6 inch over 21 front and 18 rear it kinda made the bike lean so bad it would just about fall over and hiking that son of a bitch up from a 45 degree angle to straight was a bear
Scott,
Like the skull theme... also dig the hang mans noose on the rear sissy rest.. different to say the least.
I have not heard many positive reviews of the ultima front ends (I have been looking at installing an inverted front fork system on my Dyna) and considered the Ultimas/DNA front assemblies.
I dont like the fact that you have to do a "reversion" to an older style front brake unit/front axle and use older style front wheels (or wheel bearings). I see you have converted your front end to that set up. Was it a major pain in the choad to make the swap?
Have you experienced any leakage issues from the forks or any "pulling" to one side under braking with these forks?
Thanks for your time sorry so many questions.
BTW.. I also dig that wretched B.A. looking headlight too.
