help info needed
Old 04-29-2014, 08:18 PM
superglide2000's Avatar
superglide2000
superglide2000 is offline
Default help info needed
I am wanting to know if a 98 wide glide front end fit on a 2000 superglide. Could get a good deal any info is appreciated
Old 04-29-2014, 09:47 PM
Robtarra39's Avatar
Robtarra39
Robtarra39 is offline
Yes the front end will bolt up to your frame, in 98 they used a single piston brake caliper, a 4 piston caliper made for the pre 2000 can be had or you could use a 99 or older caliper that is made for that front end, steering lock may be different but not sure
Mchad
EVO
49
07-26-2018 03:11 PM
KumaRide
08-23-2014 02:04 PM
JROCKER
02-23-2014 06:41 PM
softail99custom
03-22-2010 01:44 AM
mrbones
03-20-2008 12:16 PM
Quick Reply: help info needed
