TC88 Pushrod Cover Leak
Ok, this may be amateur hour, but I'm needed some answers haha
I just finished building my TC88 in my 01 FXDXT (Home Garage Build!)
Big Bore Kit - 10.25:1 compression
cams
stock push rods
Twin Tec Ignition
T Header
Stage 2 CV
Big Sucker
so at idle you don't notice any oil leaking
took it for a spin and dumped oil out the covers
it looks like all 4 and its definitely coming from the top.
2 questions:
1: are all pushrod covers the same length? I bought this off of ebay and was rushing to install and didn't compare to the stocks (were trashed)
2: i never could google a straight answer on this, do the pushrod retainers go under the middle o-ring and then push against the spring to hold the top end up ? how do these get inserted?
I know these might be some novice questions.....but on the bright side I just built my first TC and it runs, even did the clutch spring and andrews 30 tooth trans pulley.
once i completely finish it ill make sure to post a build thread with tons of pictures!
Thanks!
cams
stock push rods
Twin Tec Ignition
T Header
Stage 2 CV
Big Sucker
2 questions:
Thanks!
stal94gt
02-24-2016 01:58 AM
