Red Oil? Help me t/s
Just got to work and noticed on the right side of my bike I have what looks like thin red oil all over the front of the engine, a/c, rear brake pedal, some splattered on my pipes...
There is also a red ring around my right for tube. So I am pretty much guessing I busted a fork seal. I pushed down on the forks to check the rebound and it seemed normal and I didnt see oil spewing out, but it seems it makes a perfect red oil ring when it comes back up.
So basically, just looking for confirmation that its a busted fork seal. Appreciate your inputs
I really would prefer to do this work myself cause I have never done it before. I normally go to the hobby shop on base to do any work. They have a lift, but not a jack that fits my bike. I dont have the dyna lift adapters either. Jack is a future purchase but just going to bite the bullet for now and take it to the dealer. I feel like sh*t right now anyways with some kind of bug, just want to get the bike fixed andget rested so I can make a planned ride on Sunday.
the fork oil is blue in our bikes unless you have some special brand. plus a 2011 should have no reason to leak fork oil unless you had hit something or popped a wheelie and let it down real hard. Now brake fluid on the other hand is red once it has worked a bit.Have you checked your brake bleeder valves and res. level?
