Very unhappy with my Dyna "wobble"
Had the Dyna out today....just got it this past winter and haven't had that many chances to ride.
99 Super Glide. 34K on the bike. New tires front and rear, new shocks and fresh fork oil. New neck bearings...front fork fall away was set according to the manual.
I took her out today and for the second time, I felt a noticeable wobble on the highway...first time I thought it was the strong winds, but it wasn't too windy today. It's nothing too crazy but I can feel it and I DO NOT LIKE IT.
I have been doing some reading and apparently this is a common thing. True Track makes a stabilizer and if that's the fix...I am gonna get it on the way tomorrow.
But first things first....I should check the motor mounts. Any suggestions on how to check them? Any thing else I should look into? Any recommendation on which stabizer to buy? True Track? Sputhe Positrac?
Thanks in advance.
Thanks in advance.
Motor mounts need to be checked (and probably be replaced regardless of the True-Track. Look for dry, cracked rubber; worn away spots; even oil saturation. If they are bad, new mounts will help and possibly eliminate the wobble.
A True-Track or Sputhe will absolutely eliminate the wobble.
Thanks in advance.
Thanks in advance.
Agree with checking motor mounts and tire pressure or untried wheels if they are spokes. Honestly if you haven't changed motor mounts I would just replace them since you have 34k on it they are 15 years old. Look into the Vibra-Technics DYna mount. I've been reading great results and I plan on getting one this winter.
Another thing is did you change to different brand/style tires?? I had the death wobble at 80mph and spent a year searching for it, new motor mounts did all the alignments several times and low and behold it was the rear tire. Put the stock model Dunlop back on and it was gone.
tire pressure were set at Metzelers recommendation, but I will verify that tomorrow.
possible...will check
Yes, both tires are new. Rear metzeler 888 and 880 on front. Both have new tubes and were/are balanced with dyna beads.
The thought of a "death wobble at 80" scares the hell out of me....today I holding at 75mph with one hand. Its not all over the place....it just doesn't seem "planted" behind me.
