clutch adjuster screw question
I proceed to adjust my clutch today and think I got it right. Looking at tighten up the jam nut on the clutch adjuster screw. When I try to tighten the nut behind the primary cover how do I tighten when it wants to rotate? Is there some way to stop the rotation so I can tighten the jam nut?
Check out this how-to video:
It should never be that tight, someone goofed up. Also said push rod allen bolt must be held when loosening the jam nut, the exact opposite of the tightening procedure.
